Hi all I would like some help in connecting a htpc to my main pc so I can stream the media off it and use the internet connection. How would I go about doing this? Is it a problem that my main pc is XP 32bit and my HTPC is vista 64bit?
I have tried using the windows xp wizard networking tool but when I try to install this on the HTPC it installs then at the end says there was an error. Do I need anything else apart from a Ethernet cable between the two pc's? My main pc uses a wifi card to connect to the internet is this causing the error?
Basically what I want to do is what this person is talking about here:
http://www.avforums.com/forums/showpost.php?p=5006366&postcount=52
Thanking you in advanced.
