Help with converting urls?
28 Jun 2005
London
I've got a url e.g:
https://exampleurl.net/funky.aspx?id=4&spec=2
It's added to php but it doesn't like it and it only works if I turn it into:
So by using the w3school url encoding reference it will work.
If possible I was hoping someone on here has come across the same thing and found a tool that will convert it or a program. I've searched and I can't find a tool or anything that will allow me to paste in the link and encode it correctly. (I've quite a few of these to do - so would save me a lot of time than doing find and replace)
Thanks!
What are you using it for?
PHP:
<?php echo htmlspecialchars("https://exampleurl.net/funky.aspx?id=4&spec=2"); ?>
^ I think, anyway.
OK sorry about that but in closer inspection it is javascript.
I have a variable that is stores the url.
This is later called and inserted into a .swf flash movie.
I was just looking for a shortcut to rename the urls. I think I'll just use dreamweaver to do a mass find and replace.
Thanks Pho!
Ah ok. In that case try this:
PHP:
var url=encodeURI("https://exampleurl.net/funky.aspx?id=4&spec=2");
