- 17 Nov 2014
I am wondering the best way to cool all my components with the case and fans i have.
I have a h100i with 2 fans which is top mounted in my case
I have a 295x2 radiator and fan rear mounted
I have 2 fans front mounted on the case
Also have 2 fans which are attached to the side window, which is off the case in the above image.
Just wondering which fans should be used to pull air into the case and which fans should be used to push air out of the case. Thanks.
