Hi, i have just modded a Dell Dimension 4400, but there is nowere to put any fans, my current set up:
CPU Fan, being directed straight out of the back by that green thing.
PCI slot fan.
And a 120mm on side.
they are all blowing hot air out.
Some pics. [Are bad, sorry]
120mm Side
120mm Side, closer up
Back - CPU Fan.
Back, PCI Fan
As you can see a little on the side there are only little holes were the case clips in so i don't know if its doing anything?
Can i improve anything.
Graphics card, ATI 256mb something.
PCI slot fan.
120mm Side
Back - CPU Fan.
Back, PCI Fan
get some edging and a fan gaurd + 1 new fan and it will look as good as new
