- 10 Sep 2008
- Macclesfield, U.K.
Hi, i just bought said HAF case (which is feking MASIVE! lol)
But i have a few questions.
1st, how do i get the plastic front panel off to get to the fan screws? Looking in the instruction book it looks like you just yank it :-S
That right? Dont wana pull on it and snap sum clips.
2nd, is it easy to change the leds in the front fan? Is it just a case of pulling the glue off and then its a normal led to then re-wire? Or do i need specific leds?
Thanks.
Thanks.
