Hi,
I just got this case after using my Lian Li PC70 for 10+ years - I thought it'd be nice to have some modern USB ports, etc.
So first things first, I boot it up with a minimal setup and immediately the fans are making weird noises when the fan controller is set to medium or low - there's like an odd rattling/buzzing noise. It's not there with the fans at full speed.
I tried disconnecting each fan individually and it's coming from both of the 200mm fans. I then removed one of the fans and it does it even outside the case.. no odd noises when on full speed but weird buzzing at medium and low speed. So that seems to need replacing already - anyone else had similar issues?
Next I remove the front panel and it seems that two of the plastic holders (not the clips, but the guides which go into a hole on the case) were already snapped off - they just dropped out as soon as I took the panel off.
Finally, the HDD trays. It seems I have to mount my hdds in the trays backwards (i.e. connectors are facing the right side panel of the case) - seems like a good idea.. the cable management stays clean. However, clearance isn't enough - my sata cables and power connectors are going to be completely squashed by the side panel if I close it and I'm likely to end up snapping a connector on a hard drive. Have I misunderstood something here?
Has anyone got any tips on how to sort this out?
I love the look of the case and the cable management is really nice, but so far it feels like a complete dud. I'm tempted just to send it back but I'm not even sure if I can cos of the snapped plastic, which I can't prove was snapped before I opened it.
