help with corsair h100i firmware update!
How do I update the firmware on my H80i/H100i?
Please follow thes steps to update the firmware on your Hydro Series cooler:
1. Install the latest version of the Corsair Link software and use the "update firmware" button on the device tab.
2. Once Corsair Link exits a new dialog box comes up and you have to select "Corsair H80i/H100i" and then click back into the dialog box.
3. Use the choose file dialog box to select the unzipped firmware file.
4. Once you hit start it will flash the firmware and go through POST test on the H100i/H80i unit. The fans will spin up to full speed and then go back to the previous profile that was selected before the flash.
5. You can close the firmware flash dialog box and the program will open up again.
6. The service has to be restarted, so detection of the devices and inputs will take 15 to 30 seconds depending on how many you have. It will all come back up in the main program window as well as the devices window.
Im not seeing this unzipped fw file when I get to that stage:confused:
Thanks for links! If appears corsair have taken down the firmware updates!! Just great news after only installing it yesterday!
The updates were taken down because it is not recommended to do the update. There are errors with the old firmware granted, but the new firmware (1.0.4) is worse.
I do not recommend you update at this time!!!
Leave the firmware as it is.
Whats wrong currently? a bit of a rattle from the fans at the minimum RPM? if so just increase the minimum RPM a bit in the software and it goes away.
My quiet version fans are at 100% rpm,just want to have the cooler work as it's supposed to, will have to put fans into other fan headers I suppose until a proper fix is out.
