Help with Corsair Hydro H150I Pro
16 Nov 2008
West Midlands
I am getting this cooler tomorrow and will be mounting it in the front of a Corsair 465x
I already have 3 fans in the front.
Should I leave them and install the radiator In front of them, or remove the fans and install the fans in front of the radiator? Just not sure if I should have it set up as a intake or exhausting air.
The rear of the case is a exhaust and I guess I should just leave that as is?
I am also going to be installing 2 120 fans in the top of the case. Should I have these as intake or exhust?
Install rad over case fans, use AIO fans on rad still as normal too. So you create a push/pull effect.
