- 13 Aug 2011
Hi
My Son has just bought a Cougar GX-6 PSU but it wont connect onto the motherboard.
The motherboard is ASUS Prime Z270-P
Had a look at the 8 PIN - 4+4 and it not matching what is on the mother board.
On the 8 sockets there is an arrangement of Square and like D bottom connectors, 8 in total.
For the following S= Square connector D = the D bottom shaped connectors
On the motherboard and the manual it has the following arrangement
DSSD
SDDS
On the PSU it has the following arrangement.
[DS][DD]
[SD][DD]
(Note the [] denotes the separation of the two 4 pin cables that make up the 8 pins
Is there a problem with the cable on the motherboard or was the wrong PSU ordered?
I have tried looking at the arrangement for the Cougar website or the manual but it does not show it.
Will the D shape fit into a S shape with out any problems, or is the one of the cables on the power supply configured wrong.
Don't just want to force the cable in case it damages the motherboard or the PSU cable.
Please can you advise.
cheers
Blue
DSSD
SDDS
[DS][DD]
[SD][DD]
cheers
Blue
