Chaps... please give me your opinion on upgrade...
I currently have i5 3570k @4.1Ghz, z77 mobo, 16GB ddr3 ram, SSD, 980ti, running on Windows 7. 3440x1440 resolution.
I do 50% gaming and 50% Photoshop work - raw files, batch processing etc.
I want to upgrade CPU but limited by my board so will go with a package - cpu, mobo and ddr4 ram and also a new case. What way should I go to? 6700k/z170 seems the best but can I run Windows 7 on it??? Just put my exisiting Win7 installed SSD in and go? I'm a bit confused by this as seems might not be compatible?
Or should I go Haswell 5820k? Or other? Budget about £800 but want to get best I can so can leave as is for a few years.
I really want to keep Windows 7 for compatibility with some games (mostly racing).
Cheers
Cheers
