Help with Crysis 1 (via Steam)
22 Jan 2006
London
Hi there, i bought crysis 1 on steam as no local shops had it and one guy even said are you sure thats out on PC lol. anyways i've been emailing EA support but they're useless.
my max resolution i can choose is 1600*1200 yet my monitor can do 1920*1200. as so everything looks stretched out of shape.
is there setting or something that i am missing?
Totally random question, but did you try scrolling down the resolution list with your mouse wheel? If I remember correctly that doesn't work, so you need to click and hold a small box somewhere on the side of the resolution list thingy and drag it... should make sense then :P.
Yeah this used to crop up time to time. You scroll down and the higher resolutions are all there.
ha, so stupid of me, it wasn't clear in my defence but thanks guys =)
was just a little green square at the top that could be moved down. thanks again :)
