Help with data types
That's not a trivial question to answer.
This is a good list of what you have available to you: http://en.cppreference.com/w/cpp/language/types
Ask yourself what the data is, i.e a number, decimal, text string and pick a type that best represents the max/min of the range of possible input. For example, if a 10% discount is going to be a whole number between 0-100, an unsigned short would suffice, as would a signed int or unsigned char. Depends how picky you want to be.
From what you mentioned, 10% discount, probably a float/int and the other two a char array.
I agree with tnt, though I'd build my own class for a receipt printout seeing as though you need to store a few things.
