Help with deciding on detailing products
6 Dec 2002
North East
Well I've had my Fabia vRS in Corrida Red for a few weeks now and decided it's about time I treated it to a good clean. I really need some new cleaning products as I used to use a sponge for my 306 and really I need a lambs wool mitt. Anyway, I've come up with the following products and wondered if you could cast your eyes over them and give any thoughts or opinions on the choices.
Wash
Meguiars Lambswool Wash Mitt
Chemical Guys - Citrus Wash & Gloss
Chemical Guys - Strong Wash (Bug Bugger)
Clay
Sonus SFX Ultra-Fine Detailing Clay Sampler
Polish
Autoglym Super Resin
Autoglym Metal Polish
Glaze
EZ Glaze with Acrylic Shine II
Sealant
Chemical Guys Wet Mirror Finish
Wax
Sonus SFX Pro Applicators Pkg/2
Chemical Guys - XXX Hardcore Paste Wax
Interior
Poorboys Natural Look Dressing
Tyres
Meguiars High Gloss Tyre Gel
Trim & Tyre Dressing Applicator
I can't decide on the wax as I was oriignally going to get Collinite 476S but then I saw this which looks like it produces great results with a high Carnauba content.
I was tempted to buy a foam lance for our karcher pressure washer from Halfords (£15) but not sure if I can use the Chemical Guys - Citrus Wash & Gloss with it? I'm also not sure if the Strong Wash (Bug Bugger) will be worth it although with summer coming maybe it will be. Originally was looking at the Car-Lack 68 Shampoo, anyone used this?
How long will the clay last as I've got quite a few bits of tar that I need to get rid of, just loads of small pieces. I was considering some sort of Autoglym Tar Remover but if the clay will do the same then there isn't much point in buying the tar remover.
Also require some microfibre clothes but you can pay quite a lot for them so was thinking of heading to Poundland as for even £1 each they're a lot cheaper than online.
Thanks in advance :)
[TW]Fox;11558353 said:
I've got the Megs tyre gel and I prefer the Autoglym spray stuff instead, leaves a better finish. What does the glaze do?
I'm suprised about the Megs tyre gel, I always thought it was one of the best. Apparently you have to layer it get a shinier finish, the more layers the shinier it becomes.
The glaze adds a wet look and more depth to the paint - Results
