Hello all!
Well after scratching my head for a few weeks and reading and learning as much as I can, I thought I’d finally post and get some advice from the people actually in the know --- > you guys!
Basically, I don’t upgrade my PC often – and I expect a fair amount of ridicule when I say I’m posting this from my first build PC (Shuttle FN45, 9600XT, Athlon 3200!!) from 8 years ago…. (yeh… I know….
I have an Asrok HTPC in the living room that I stream movies to from this one – but I feel the time has come to update this main PC to overall give me a better user experience – even just for web browsing and youtube playback…!
Priorities for the build:
- Will be a general use PC that can handle 1080p playback without issues.
- Some encoding and media work (editing, rar extraction etc..).
- No gaming but excellent playback of H.264 and apple/camera video .mov extensions (which the 3200 currently just refused point blank to do!
- Good storage – at least 2TB (over 1 or 2 HDD??)
- At least 4GB ram
- Enough Power to upgrade further extra HDD in the future…(?)
- Small form factor would be nice but not essential - card reader would be good, usual DVI, HDMI outs as well.
- Will need new OS as I’m still on XP (*hangs head in shame…
I don’t update my PC often (can you tell?!) and would like it to last at least 5+ years without struggling (like my current set-up….. don’t laugh…..) I have considered 2 options:
1) A budget build/buy to kick start me into the 21st century circa. £300-£400 – maybe using the i3 550 like this http://www.overclockers.co.uk/showproduct.php?catid=&prodid=FS-270-OK or i5 760 or an equivalent AMD - going on the basis that I won’t upgrade it that often, from reading on here, the AMD chipset will have greater longevity to upgrade in the future….?
2) A mid range SB build (c£500) that will be a lot more than I need but hopefully mean I won’t need to upgrade for quite a few years (although 8 year like my AMD 3200 is probably pushing it!
The new SB processors appeal to me as they have the IGPU but quite frankly it’s looking that I’ll be nearer the £600 mark than £500 if going for a i5 2500K on a Z68….. (no??)
I quite like the look of the bit-tech build (minus the graphics card and replacing board with a Z68): http://www.bit-tech.net/hardware/buyers-guide/2011/05/10/pc-hardwar*******-s-guide-may-2011/3
For me P67 mobo isn’t really an option (I think!) as then I’d need to spend extra on a dedicated graphics card – which defeats the purpose of getting the new core i processor in my opinion (if you’re not a gamer etc..). But I would like the opportunity to OC at some point– hence the H67 boards are out of the equation as well…. and I’m left only with the Z68 option... (is that right? )Can I get a Z68 + i5 2500K with 2TB and 4GB ram + Win7 for £500? And would this even be the best option for me?
Or should I stick with the P67 and get some sort of budget card??
Or stick with an H67 and spec down to a i5-2300 and forget the OCing? I saw this at PC world (*heads for cover…!) at the weekend for £399 with 3GB ram, a crappy tower and 1TB HDD.
I understand that anything I choose will be a significant step up from what I have already – but question is do I go for already a pre-built budget set-up (which will handle my needs) - or spend a bit more and try to get my hands on the new SB technology? Or for what I need, I should save some money (always a good thing in my book!) forget about the new SB stuff and go for a good older i3 or i5…(or other quad core older processors) or AMD build if ?
I like the value offered by the ET1862: http://www.overclockers.co.uk/showproduct.php?prodid=FS-014-AC&groupid=701&catid=1916&subcat=
And the Primo ignition seems like good value: http://www.overclockers.co.uk/showproduct.php?prodid=FS-270-OK&groupid=43&catid=1078&subcat=
(ALTHOUGH it seems I can build it to the same spec – BUT WITH a 1TB drive using the components and OS for the same price (roughly)…?)
Intel Core i3 550 3.20GHz (Clarkdale) (Socket LGA1156) - Retail £94.99
"Primo Ascension" Intel Core i3 H55 DDR3 Ready Barebones (Socket 1156) £89.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £40.99
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £39.98
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) £17.99
Samsung SH-D163C/BEBE SATA 16x DVD-ROM (Black) - OEM £14.99
Approx. £390 with OS
Would be nice to have a quad core i5 (non-sandybridge) option if it can fall into £400-£450ish budget.....
I’m really bad with decisions like this – and considering I’m gonna be stuck with it probably for the best part of half a decade at least, I’d really like to get it right….
Sorry for the long post, and all the questions and options (at least I’ve done a bit of homework!)
Any and all advice welcome – build spec/options to my budget very welcome also.
Many thanks!
Raf
)I have an Asrok HTPC in the living room that I stream movies to from this one – but I feel the time has come to update this main PC to overall give me a better user experience – even just for web browsing and youtube playback…!
)- Good storage – at least 2TB (over 1 or 2 HDD??)
- At least 4GB ram
)I don’t update my PC often (can you tell?!) and would like it to last at least 5+ years without struggling (like my current set-up….. don’t laugh…..) I have considered 2 options:
)The new SB processors appeal to me as they have the IGPU but quite frankly it’s looking that I’ll be nearer the £600 mark than £500 if going for a i5 2500K on a Z68….. (no??)
Many thanks!
Raf
