Hi all,
Having a right ballache getting chrome to deploy and install via a GPO. I have created a simple GPO called InstallChrome and linked (and enabled) it to a test OU. Server is 2012R2 and replication appears to be working from my limited access. So I drag PCs into this test ou, and reboot them When I look at RSOP.msc, I see that the GPO has applied but has failed because it cannot locate the source of the installer. Now, if I UNC directly to \\<serverDC>\NETLOGON and manually try to run the MSI, it fails also. I can see the MSI amonst the files, but it will not run - exact same error. Now, the MSI is fine because if I copy it to a shared drive on my admin PC, it runs fine. Am I right in thinking that because it's a machine policy, not user, NETLOGON on the DC needs the security group that contains the PCs added to the permissions on the server share, even if it's read only?
Even stranger is that my Windows 7 test PC works, but there is no WMI filtering applied at all - it is literally a simple Software Deployment policy tied to a test OU.
Any help would be great appreciated!
BTW, I'm pretty new to managing policies. I strictly shouldn't be doing this at work as I'm only desktop support, but I've got unofficial permission to have a go at this so my level of fiddling is severely limited.
Thanks!
Thanks!
