Hi.
Running dual screen set up (XV273 and XB271HU)
1600x
asus crosshair 6
2080ti
g skill trident z 3200 ram
Before problem surfaced have not changed hardware or updated drivers or added extra software
Getting blue screen when gaming (most of the time when going between screens or resizing a game but can also happen on game load, or just gaming) mostly 6 problems below. Also it can BSOD in couple minutes on load game or over 30 min gaming,
- event id 41, 117, 144 or 161
- "system service exception" or "critical process died"
- Also not every time dump file has been created (probably to make diagnostic even worse)
What I have done so far:
- Checked all the Temperatures - they are ok
- Removed all OC
- Bios update even tried last Bios what worked.
- Reseted many times rams, gpu
- Tried different pcie slots
- switched dp cables and connections
- run one monitor at the time
- Clean windows install + drivers
- Run different rams (done health checks) (one ram at the time), all healthy
- Checked hdd (run one by one, done health checks, installed on differend drives windows running only one drive), all good
- Run with minimum hardware, boot drive, one ram, pump (different configurations)
- run verifier, sfc / scannow, DISM /Online /Cleanup-Image /RestoreHealth nothing found/fixed
- installed drivers what been working before
- Run windows, with and without system updates
Strange things besides above:
-Couple times when entered Bios keyboard and mouse did not work. Had to restart pc to get them working
-when pc been turned on monitors wakes up in strange way now, wakes up main monitor shows asus logo, switches to other and shows some dots circling, and then back to main monitor for windows log in.
- might be because of bios update, but now have a white - blinking in main monitor at upper left corner before entering bios
- Sometimes when opening some aplication monitor (one or both) goes to sleep and takes a long time to awake.
- once when both monitors were conected on windows install half way through, before message "gathering info, it can take some minutes" main monitor went to sleep and windows install continued on other.
Any suggestions, advice, help, etc
1600x
asus crosshair 6
2080ti
- Removed all OC
