Help with disk config please!
20 Jun 2004
Essex
Can someone explain how I can delete drive D? For some bizarre reason it's marked as a system drive when Windows has only ever been installed on C, i.e. disk 1.
WTF has happened here? :confused: Why isn't C the active system partition anymore?
It would seem you had your D drive set as boot and installed Windows 7 to C:. Meaning Windows put the boot information on the D: partition.
There is a tool, bcdboot that can sort this out.
Open a command prompt with Administrator rights and use the command:
Code:
bcdboot c:\windows /s c:[/SIZE][/FONT]
I would suggest backing up anything important before using this, just in case :)
Remember to change your boot order in the BIOS after you run the command.
