I am trying to create a site on dreamweaver but am having difficulties getting it to look the way I want. I want a template to start with so the title and other bits and pieces look the same on each page. This is what I want it to look like (bit basic but the general idea is there):
So the jist of it is the title and the standard writing area will be the same on each page but the three editable regions in the middle will be (mainly) different on each page with different writing and bits in them depending on the page.
The problem I have is that I can't get the 3 editable regions to be seperate and they need to be seperate (meaning i can't just use tables) as the 3 regions will change sizes depending on the page. I have tried using div tags but they go right the way across the page so I can't stick the three next to each other.
So is it possible for someone to give me a bit of guidence as to how I can stick 3 editable regions next to each other, or quickly make a basic template and let me know how you did it?
Thanks
Thanks
) joey posted some good links. give them a read - easy to learn, difficult to master
Damn!
