Help with driver
16 Nov 2011
Hi I'm having a problem with my pc and I'm not sure what has happened to it. Everything was working fine the last time I used it but yesterday when I turned it on the computer boots up as normal until I get to the home page I can see my wallpaper but there is no app icons.
I got fead up with trying to solve the problem and completely uninstalled windows when windows reloaded everything was fine but when I reinstalled the driver for my gtx 780 classified it went back to the same thing wallpaper but no apps :(
Can any help me?
A GPU wouldn't make your icons disappear and something else would be at fault.
Can you do a system restore to a previous time (a time when you had the icons) and see if that sorts it?
