Hi Guys,
I'm about to install a dual boot setup. I would like to keep Vista as my primary OS on my Raptor, whilst installing XP on a small partition on my F1. I'm currently running on Vista 64. XP will not be used often, however i need it to play a game that is poorly supported within Vista. My plan is to:
Also, i plan to use the remaining space within my F1 as an applications / games drive. With both OS's on separate partitions / drives, is it possible to share apps and install games on a different drive / partition.
For example, i would to install COD4 on the remaining F1 partition and play it from within Vista. Essentially, i want to keep my raptor partition as uncluttered as possible.
Any help would be greatly appreciated!
Cheers
- Load XP onto my F1 (deleting the Vista partition)
- Load Vista onto the Raptor
- Shrink and partition XP from within Vista
Cheers
