Help with Dual radiator - high flow
16 Nov 2008
Start building new rig, nothing special - LGA2011 platform base. But planning to do average overlock. Decided go for water, up to now have this components -
CPU - XSPC RayStorm
Pump - Reservoir combo - XSPC X2O 750 Dual 5.25″ bay Reservoir Pump
But struggling decide what 2x120 radiator to buy. Size of radiator is limited by case - CM Storm Trooper. RX radiator to fat.....
Thanks
RTM it :)
I'm lolling too hard to :p
Have you already got the pump res or any of the other watercooling bits?
I have CPU block and Pump - Reservoir combo, connections and etc... just need radiator. I was holding with radiator until I received case and measured clearance inside for him. Plans was to fit XSPC RX240, but find out after by measuring clearance, that it is to fat...
P.s sorry d_brennen for signature....:)
Clarence with XSPC RX 240 -
I need something less fat, but with good performance. Because I do not have the necessary knowledge - I am asking for help. RS or RE series radiator with fans have to be around green line.
Blue line is RX size radiator without fans.
Heh, I like it. I was just giving you the heads up before a Don come along and removes it for you ;)
:rolleyes: I hope, that Don are to busy to chase some gift signatures.... Ups, looks that is not busy at all :D
Sorry Don
can you not get the fans in the plastic cowling of the case
Only one fan fits under cowling.....
In general, very happy with the case, is great, there some pictures, when I compared with my HAF 932...only not so friendly for watercooling.
