- 24 Feb 2004
- Leeds/Cyprus
I've spent hours googling trying to find a good, simple guide to DVD authoring and it's been eluding me, mostly because each guide is specific to a particular piece of software, and then when I donwload the piece of software in question it turns out to be a limited trial version that can't do what I need it to unless I pay.
So I turn to the forum.
The problem:
A friend has sent me a DVD movie of a concert of his. However, either the disc is physically damaged, or he messed up making it, because, when I play the disk using any media player it freezes during the menu. However, the actual movie seems to be ok, because I can browse the disk and open the .VOB files using VLCplayer without a problem. I copied the two main movie files onto my hard disk (which I could identify only by size) so the actual movie's been salvaged, but I'm still stuck as to how to actually author a movie dvd so I can send the concert recording as a demo.
What I need to know:
1. Which is the best freeware DVD authoring tool? I own Nero, but the version I own doesn't seem to have any functionality for creating DVD menus! All you can do is drop the .VOB files directly into the disc's file structure, and, since the dvd menu on my original disk isn't working, I need a piece of software that I can use to make a new one.
2. How do I use said authoring tool to make another menu so I can rebuild a proper movie dvd of my friend's concert?
3. I have another short DVD movie on a separate disk that we also occasionally send out for demo purpopses. It would imho look more professional if I could send them both as a single DVD with multiple titles on it. Is this a simple matter of renaming VTS_01_1 to VTS_02_1 and creating an extra entry on the DVD menu? Or would it be more simple to give it up, re-transcode them to .AVI files and just drop them on a data DVD?
The problem:
