Hullo everyone,
I am having a really annoying problem with my PC. I'll describe it briefly here:
http://forums.overclockers.co.uk/showthread.php?t=17561460&page=1&pp=30
What I'd like everyone to do, especailly if they own a ViewSonic VX912 and/or an ATI X1900 is to help me with what I've requested in post 36. This is to download Powerstrip, run it and then go to the "Monitor Information" page and use 2 options from the drop down menu in the bottom left corner. These are "read data directly from monitor" and "update EDID", if possible.
I get the following error messages:
Thanks,
Oliver
- I upgraded my graphics driver.
- On the following reboot I get no display over DVI when Window's scrolling loading bar is done.
- No amount of driver fiddling or reinstallation of Windows has helped.
- After first thinking it was a graphics card problem, I know believe that it has more to do with my monitor for a combination of reasons.
- "DDC communication with the monitor failed or is not supported"
- "A valid EDID was not detected on the selected monitor. Do you want to scan the bus for a EDID EEPROM?"
- "A valid EEPROM was not found"
Thanks,
Oliver
