Help with Excel VBA
4 Mar 2003
Hi there,
I require some help please. Basically I need a range of cells to be selected when I press a tick box (these cells will be copied into another spreadsheet when a macro is activated). The thing is the range it needs to select is relative to where the tick box is.
Code:
Sub CheckBox4_Click()
    Dim cBox As CheckBox
    Dim LRow As Integer
    Dim LRange As String
    Dim cell As Range
    Dim rRow As Integer
Application.ScreenUpdating = False
    LName = Application.Caller
    Set cBox = ActiveSheet.CheckBoxes(LName)
    'Find row that checkbox resides in
    LRow = cBox.TopLeftCell.Row
    LRange = "I" & CStr(LRow)
    'Change date in column I, if checkbox is checked
    If cBox.Value > 0 Then
        ActiveSheet.Range(LRange).Value = Date
    'Clear date in column I, if checkbox is unchecked
    Else
        ActiveSheet.Range(LRange).Value = Null
    End If
End Sub
This is currently what I have set up. Say for example if the tickbox is selected and the date is displayed in "I7". Then I need it to select the range "B7:I7". It's just the relative thing that I'm stuck on because obviously if the tickbox was in cell "G25" it would still highlight "B7:I7" and not "B25:I25".
Hope that made sense lol.
Not sure I really understand but why wouldn't this work? You've done all the hard work.
Code:
[COLOR="Red"]        ActiveSheet.Range("B" & CStr(LRow), "I" & CStr(LRow)).Select[/COLOR]
    Else
    End If
Just add the line I've highlighted.
.Offset(x, y)
For example, Range("A1").Offset(0,1).Address will give you B1, and Range("A1").Offset(1,0).Address will give you A2.
However, in VBA try to avoid absolute cell references. Instead, define a named range. For example, define "tick_box" as a named range and set it to refer to where the tick box is and then use Range("tick_box").Offset(x, y).Address to move y columns and x rows relative to it.
You then change the cell "tick_box" refers to, and the code still works.
