Help with F Panel!!
6 Oct 2011
Lost the ability to turn my PC on by the front switch after upgrading PC.
I have a g1 Sniper z87.
Sockets on the F panel on the right hand side are:
PLED+/PLED-/ PW+/ PW-
HD+/HD-/ RES-/RES+
Now I have plugged into these sockets...
Power LED+/ Power LED- / Power SW+ / Power SW -
HDD LED+ / HDD LED - / RESET SW- / RESET SW +
Where am i going wrong?
Thanks.
Take the Power SW wires back off and try using a screwdriver or needle nose pliers to short those two pins, if the PC responds and turns ON then the problem either lays with you not putting the connectors on properly, a break in one of the wires from the case power button or the power button itself.
