Deleted member 6068
Deleted member 6068
Right flashed my BFG 7950 gt oc with the standard bios cause for some reason the fan speed would not alter and when i rebooted i got a couple of quick beeps and one long one which is a vga problem anyway tried to reflash using same usb flash boot with latest nvidia flash program but would not work.
so i put the usb flash drive in my dads comp and booted from it and it says program too big to fit in memory even though it worked the first time.
anyway i went out an bought a new pci-e graphics card and want to know if i can also put the borked card in the other pci-e slot and try and flash it back without risk to my new 8800gs , i have looked on the net for instructions to flash it with there being two pci-e g-cards in there but cannot find it and also still cannot get the flash program to work as program seems to be to big to fit in memmory for some strange reason.
could some one be so kind to email me the files needed for a boot disk not a preconfigured exe like the one's on the net and also instructions on how to flash a pci-e card along with another pci-e card without risk of flashing the wrong card.
thanks
steve
thanks
steve
