Have today swapped out my old 7850 for an MSI 390X which is great, but being a much bigger card it's added 3 or 4° to my CPU temps, that were already marginal.
Currently I have:
1x120mm fan on front intake
1x120mm fan on side intake
Corsair H80 mounted on case exhaust with 2x120mm Noctua fans in push pull config - exhausting out the rear.
1. I'm thinking about making the rear exhaust an intake to cool the rad better, but what do I do with the others? Where should I make the exhaust? the front, top or side?
2. The side fan is currently blowing onto the GPU, but even without it the temps were fine, like 77° after an hour playing, so should I make that an exhaust to dump some it's heat? I'm guessing at the moment the side fan is just helping to spread the GPU heat around the case?
Any help appreciated
Currently I have:
