Help With Fans
11 Jun 2020
UK
I've recently within the last couple of week done a Full PC Upgrade and the final piece of the puzzle is the fans. First time I've used an AIO and I went with the Corsair H150i Pro XT 360 but the fans are not RGB so it's making my system look odd. In total I want to use 6 fans, 3 Intake on the front of the case and in front of the Radiator, 2 Exhaust at the top and 1 rear Exhaust.
I Don't know if I need a specific type of fan for my Radiator but ideally I need to have all 6 fans matching so whichever fans I get recommended for my Radiator ill get another 3 for the rest of the setup.
I need them to be Corsair and RGB.
Any help would be greatly appreciated.
If you have a commander pro (which I do) you can bolt any PWM fan to it and control it.
I have a mix of noctua, bequiet and corsair fans and they are controlled through the pro and icue...
I want all 6 fans to be the same Corsair and RGB but don't know which are best for my setup
Compared to the noctua fans I now have, corsair fans were very noisy by comparison. I mean very. The sound of the noctua fans, even at max rpm is just nicer than the corsair fans at the same rpm.
I now have quieter fans, and a couple of RGB strips in the commander pro thanks to the lighting kit I bought (4 strips, only used 2). The commander pro will do 6 fans, 2 RGB connections (can chain together strips). So that takes care of all my unicorn vomit needs and gives me the opportunity get decent non-rgb fans.
All of it is controlled through iCUE with the commander pro.
It's not a cheap solution for sure, but it is a good one for me and I would recommend
If you want Corsair fans ML series are the ones. If not there are plenty others.
Ok...the icue software and command pro can control everything.
