Hi there, I need help with this one as my Dad's PC is behaving somewhat erratically and I don't know how to go about diagnosing the fault. (happy to buy new stuff to fix but which bits to fix!!!). So hopefully the knowledgeable folks on here can tell me what to try.
The PC is an ('purple shirt' number) P4 3.2ghz, 1gb DDR and Windows XP, 500gb HDs. Its about 3-4 yrs old I think.
On bootup the PC often (but not always!) hangs at the 'intel' logo (i.e. after BIOS screen and before Windows), and the Fan spins up (rather noisily actually). Other times it can hang at a black screen (again before Windows) or sometimes on the XP loading screen. However, if it gets into Windows there are no problems whatsoever!
Can anyone give me a clue what component this might be? Or how best to go about running tests to narrow it down?
My 'troubleshooting' tends to be a complete wipe/reinstall of the OS (and replacement of obvious bits for my own rig) but my Dad has lost his OS discs in his recent move. I have a feeling it is not the install though anyway.
Any help appreciated guys!
