Help with First Boot
16 Mar 2010
Built my first computer last night and SURPRISE! it doesn't work!
I've gone through with the manuals and double checked all connections and still a bit lost. When I turn on the computer all the fans turn on but the Lights on the front of the pc do not, and the monitor doesn't come out of energy save mode.
I tried this with the onboard VGA output on the MOBO without the GPU installed and via the GPU using the DVI to VGA adapter (using temp screen during setup). The light on the MOBO is on when I connect the power to the system. also there is no system speaker so I cannot pickup on any error beeps.
any ideas?
we have all faced this problem at one point
firstly i would try taking everything back to absolute basics
GPU CPU 1 stick of ram
see what happens then (if it doesn't work post pics)
Sorry for the cufufle! i had forgotten the second power cable that connects to the MOBO
all up and running now, I also had the LED the wrong way around although i still say the manual has it the incorrect way round!
all up and running, just working through installing the basics to then create a restore point now.
Thankyou for help though.
