help with first new build
12 May 2015
Hi guys just new here and new in general to the overclocking and looking for some help and advice for overclocking my system..
I built my own system from old run down slow thing and now my specs are: Motherboard - Gigabyte 78LMT its the rev 5 model with AMD FX6300 6 core, 4gb ddr3 corsair vengeance 1600mhz ram, graphics card - asus geforce gtx 750ti with 2gb ddr5, psu - corsair cx600, my cpu cooler is the - cooler master hyper 103,am running windows 8.1 pro 64bit.
I have downloaded AMD overdrive and MSI afterburner and also have CPU IDHW Monitor. I am looking for some guidance or help if possible to over clock my system. I have searched the net and cant seem to find a guide anywhere that suits my set up. any help or even pointed in the right direction will be great thanks
so had a play around with the settings and have a rough idea of what am doing now thanks to the guide.
am just not sure on what the voltages should be here is picture of it i never saved the settings as i was not sure what was the correct vaults
