- 3 Jul 2006
- St. Neots
Right... I have bought most of my kit and hacked my case ready to fit it but need some advice and help now!
My loop is-
Laing DDC-1plus pump with plexi glass res >
Nexxos Pro II dual 120mm rad >
Danger Den TDX 775 CPU block >
Nexxos Pro I single 120mm rad >
Danger Den NV-78 rev 1.1 SLI GPU blocks >
pump
I will be running a Core 2 Duo E6600 2.4GHz CPU when its delivered!
Dual nvidia 7900GT's in SLI
All hosing is 1/2" tubing.
All fans and pump are run through a Nexus fan controller (dual rad fans link so spin same speed) so I can control noise and cooling.
Dont know the mobo yet as SLI ready ones are not avaliable! Think will get a Asus or DFI when they get released!
If I had known that Intel had signed up with ATI I would have bought bloody crossfire gear!
Oh well!!!
Anyway, I have read that I should run the system for 24 hours or so without power to any components other than pump and fans to check for leaks, purge air etc.
But how to I get my PSU to power up without connecting it to the mobo
I have a Hiper Type R.
Any recommendations about loop, if its ok etc, and the PSU issue would be greatly recieved.
My loop is-
pump
Oh well!!!Anyway, I have read that I should run the system for 24 hours or so without power to any components other than pump and fans to check for leaks, purge air etc.
I have a Hiper Type R.Any recommendations about loop, if its ok etc, and the PSU issue would be greatly recieved.
