Need a bit of advice regarding an advert, I've only ever sold one car before and it was to a mate.
I've gone for the following so far:
It's the first draft and not 100% finished, going to go through receipts etc and make sure I have not missed anything out and that all my dates are correct.
I want to put the car up for sale asap so was thinking of putting it up today on the owners club and then editing my post as I get new parts etc, or do you think it's wise to just wait?
Have I gone in to too much detail (if such a thing is possible?)?
I am selling my R5GTT after 5 ½ years of ownership. Most of that time it has sadly just sat in the garage as I lost interest in it but it is now up and running.
1989 F reg Phase 2 in black with sunroof
108k miles
MOT until Feb 2011
Tax until July 2010
CAT 1 alarm
CAT 2 immobiliser
New tyres all round
Service stamps in the booklet until 70k (1995) and a folder full of receipts for everything after.
Engine
Recently run on an RR it put out 125bhp but wasn’t holding boost at higher revs so it’s now running standard boost via the actuator (had a bleed valve fitted but this was causing problems and the car wasn’t holding boost, so it was removed).
Standard carburettor (jets etc).
Unsure of the turbo, it appears to have a slightly bigger than normal housing.
Strapped and flowed OEM intercooler .
Lightened and balanced flywheel.
Cone air filter.
GT Tuning carb elbow.
GT Tuning downpipe.
Magnex exhaust.
Red Samco boost hoses.
New radiator fitted about 3k miles ago.
New starter motor fitted around 1k miles ago.
New brake master cylinder less than 1k miles ago.
New spark plugs fitted less than 1k miles ago.
Transmission
Volvo 440 turbo clutch.
Gearbox fitted from a car with approx 60k miles.
Suspension and brakes
It’s lowered about 30mm all round but unsure exactly how much.
I believe the rear left shock absorber is a bit dead because it makes sounds when going over bumps.
Refurbished front brakes with rears just rubber outer casing changed, still have the rest of the refurb kit which I will throw in with the car. All new bleed screws too.
Brakes are a little spongy at the moment which is partly due to the brake fluid reservoir seal being a bit poor so I’ve ordered a new one. Brakes are also sticking a bit which I guess is down to lack of use.
New handbrake cables fitted less than 1k miles ago.
New steering U/J fitted as there was a lot of play in the steering wheel, this eliminated some of the play but there is still some slack present.
Interior
Standard interior, the driver’s seat has a couple of tears and the passenger seat has a little hole, although I’d say it’s in good condition for its age.
Exterior
For the last MOT it needed the battery tray cut out and some holes in both sills plated and welded.
There is some rust around the aerial and under the rear driver’s side window.
New unpainted front bumper (fog lights fitted but not currently wired up as there are no wires, I’m told you can buy that part of the loom though).
New unpainted grille.
Bonnet needs a respray.
Parts included with the car
Carb service kit (minus one gasket that I recently fitted to the carb)
New wishbone poly bushes
New unopened goodridge brake hose set
New water pump
New clutch cable
Second hand throttle cable
I have also placed an order with R5GTT parts for radiator cowling/ducting and a new brake reservoir cap and seal.
Trying to be as honest as I can because I'd rather people know as much as possible about the car before coming to look.
Any further questions, please ask.
