- 18 Oct 2002
- Lincoln
Help Looking for new Fiesta CD Player - MK5
I've just bought a 51 reg fiesta with a factory fitted tape player/radio and was wondering how i would go about changing it for a cd player.
I've heard there are mounting kits avaliable to put normal radios into the space without leaving a gap but i was wondering how this would look.
Also i was thinking if the standard ford radios are decent then which would be the best that would fit my fiesta properly.
just incase you need to know the exact model is a Ford Fiesta Fun 1.3.
Thx in advance.
Thx in advance.
