Hello,
first time poster in many years.. lost my old user name so had to create a new one.
I was hoping somebody would be able to look over my spec below? I am quite a bit out of touch with the latest hardware so apologies if I have missed something. I have also decided to have OC build the system (unless its much cheaper to build myself) and have based it from the "Titan Bayonet" Intel Core i5 6600K @ 4.4GHz DDR4 Overclocked Skylake Gaming PC" which is offered on the site
Case : Phanteks Enthoo Pro M Midi Tower Case with Window - Black
PSU : SuperFlower Leadex 550W 80+ Gold Rated
Motherboard : Gigabyte Z170XP-SLI (Socket 1151) ATX Motherboard
CPU : Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - OEM
Cooler : Prolimatech 81 - 120mm Tower CPU Cooler
Memory: Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Black (CMK16GX4M2A24
Primary : Samsung 250GB 850 EVO SSD 2.5"
Secondary : Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)
Graphics Card KFA2 GeForce GTX 980Ti "Infin8 Black Edition" 6144MB GDDR5 PCI-Express Graphics Card
Optical Drive OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
Total - £1,255.00
The pc will only be used for gaming and I plan on buying a 1440p when i decide which one
Thanks,
gordon
Total - £1,255.00
Thanks,
gordon
