Hi All,
Having some trouble with getting my RAM stable at its rated timings - would love your guys help please!
I'm using this kit of G.Skill Samsung B-die PC3200 on an Asus Crosshair VII (X470) with a 2700X (full spec in sig)
Was previously using The Stilt's 3200MHz safe profile that is built in to the BIOS, but had to turn off 1T command to get it stable (was Memtest error free for 12+ hrs when I first built this rig).
Recently I have been getting black screen / CTD in Destiny 2 and Borderlands 3, so wanted to double check and make sure it wasn't a RAM problem. I just ran Prime95 (large FFT's) now and it threw up an error after ~9 hours.
Maybe the RAM is slowly pooing the bed, but it's also possible that it was never fully stable to begin with... Is there anything specific I need to do when setting it up? E.g. other voltages or timings, chipset, infinity fabric. Could a weak memory controller on my 2700X also be an issue?
Thanks!
Su
P.S. I tried to post with the XMP (DOCP) profile and I think it failed and reset back to super slack timings of 16-22-22-53-75-2T @ DDR3200. I am running Prime95 again at these settings to rule out straight faulty RAM.
Thanks!
Su
