- 27 Dec 2006
- Northampton
Need some quick advice.
I have an M4 SSD as my primary on the SATA3 connection with my OS
I want to take my 2 x 1TB and set them up as RAID 0 along side my M4
1 x SSD C: 128GB
1 x RAID D: 2TB
The 2 x 1TB are connected to the SATAII connection and is controled by the Z77 chipset
When I go into the bios to set up the raid, I choose SATA MODE to RAID and then save and exit. I set up my RAID 0 configuration and looks all fine.
When I reboot, it goes past post and loads up the windows loading screen for a split second and then blue screen.
Have my setup RAID correctly?
And whats the differance between the onboard chipset Z77 doing the RAID than to the Marvell SATA controlling the RAID?
1 x SSD C: 128GB
1 x RAID D: 2TB
