- 19 Jan 2010
- Merseyside
Hi, will just do a quick post then reply. Just finished moving all my stuff around and having nothing but trouble with this board, at first it wouldn't boot so I found a kind of fix online, you press the ignition switch in and en power button, then I noticed no display output, I've tried on board and my gpu, at first the gpu wasn't spinning either then I found you had to press the power button twice.
So I have checked all cables, tried all sticks of ram in all slots, CPU is seated correctly, right now there are no graphics cards in just the CPU and two stick of ram, all fans are spinning but no display output.
Please tell me this is a regular problem and there is a fix/work around.
Thanks,
Dane
Thanks,
Dane
