Hi All,
I have been contemplating buying a new GFX Card so I can run some games a bit smoother with less heat. Also looking for 4k card so I can buy a 4k monitor (Is this worth it?) Ibeleive that I should be looking at using the display port now?
I am really not up to date on any of this now and would appreciate any feedback. I will leave my computer specs here so that it may help with graphics card choice.
Windows 10 Pro x64
Intel Core i7 6700 @ 3.4GHz - Skylake
24GB DDR4-2133 (1066MHz)
Asus Z170 PRO GAMING (LGA1151) Motherboard
AMD Radeon R9 280 4GB MSI Gaming
Now my budget is ~£300 willing to go a little above.
Cards I have been looking at are
GTX 1060/1070 (I know there is a price jump)
Radeon RX 480 Nitro 8GB
Or would it be worth buying another R9 280 and going crossfire? I would like some better quality though.
Thanks for any help you can give.
Windows 10 Pro x64
