Help with Graphics Card choice
11 May 2009
Stoke-On-Trent
Hello, I have the ECS AMD690GM-M2 AMD 690G, this motherboard.
I am interested in ATI Radeon HD 4670.
Would this be ok?
My other specs are:
Windows XP
AMD Athlon 64 x2 Dual Core Processor 6000+
3gb RAM
480W PSU
Thanks in advance :)
I think I probably will go for one of the 4770's then, but they are out of stock at the moment, any idea when will be available?
Thanks
Ok thanks, I'll go for the 4770 then. Do you have any idea when it will be in stock?
I sent the shop a webnote but they are unable to say when they will re-stock.
I really want a new card as soon as possible so if I was to go for the XFX ATI Radeon HD 4830, this should still be fine with a 480W PSU?
yeah the 4770 is a replacement of the 4830, so the 4830 wont be too far behind it in performance terms, and yes it should work as long as you have enough amps and a PCI-E power connector, which PSU is it?
Ah right, thanks, it's the Xilence 480W PSU, is the PCI-E power connector one of the wires coming from the PSU?
