Help with h100i v2
17 Dec 2016
england
Hi all, built up my new rig last night, had a few problems along the way, one being when installing the h100i v2 one of the nuts wouldn't screw down for some reason so I've had to cross thread it on there, now it's ok for the minute but when I take apart which i wanted to do tonight to install a different cpu I won't be able to get that nut back on there and hoping I haven't cross threaded the backplate. Would it be possible to use a bolt and nut if I can find one to fit? Or do you have any suggestions on what I can do?
Many thanks
Contact corsair and they might send you a new nut and bolt to replace the one you have crossthreaded.
