Help with Haf X
18 May 2012
This is probably a nooby question but where do I connect the cable of the side panel to on the Haf X?
I ask this because I recently purchased a pre built Pc from Overclockers but they have left the side panel fan cable unconnected and I see no immediate places to connect them.
I found a slot that took the cable on the Sata backplane but that doesn't seem to work
P.s The said cables have two ports available with one having four pins and one having four pins that are hollow ( correct me if I'm wrong but these are called Molex I think)
Help quickly would be awesome
thanks
It is a molex connector and needs to be connect to a molex cable from your PSU. Hope this helps.
Edit* I don't actually own a Haf X so someone correct me if i'm wrong.
