Help with HD detection / booting
25 Nov 2011
Flat Norfolk
My hard drive isn't being detected. SATA and power cables connected. I read online that maybe my mobo is 'IDE' mode and I might need to switch it to RAID, but I can't see hopw I can get into BIOS. System just starts up, brief message flashes up and then it says 'Reboot and select proper boot device or Insert Media.....press a key'
Got into BIOS... It detects my Samsung HD, but does not seem to want to boot from it,.. I just get taken back to the above screen
Please help
If it's new - I assume it's empty - are you saying you've been trying to boot from a empty HDD or am I missing something here? :confused:
If its new then there is nothing to boot into! Put in the operating system CD/DVD/USB and start the installation. While installing, you will be asked to partition your hard drive. After the installation you should be able to boot from your HDD as now it will be bootable.
I bought it from the bay second hand, empty I presume.
I guess I'm trying to boot from an empty HDD.....
Nothing wrong with it. You just need to install an operating system. Follow a guide online or a video on Youtube if you don't know how to install an OS.
