Right guys, I have a problem. I only have one DVI and one VGA port on my monitor but the DVI is already in use. At the moment, I have my xbox set up as this:
Xbox goes to the HD PVR via a component cable and then the HD PVR goes to the TV via component.
The TV I have is horrible so I am looking for a way to connect the HD PVR to my monitor via DVI but it is already in use
. So, is there a cable/device I can use to connect two DVI devices (PC and Xbox) into one DVI port on my monitor and then have the ability to switch via a button or something??
Cheers!
. So, is there a cable/device I can use to connect two DVI devices (PC and Xbox) into one DVI port on my monitor and then have the ability to switch via a button or something?? Cheers!
