- 7 Aug 2003
- Bedfordshire
Hi everyone,
Well, my room is nearing completion, just the carpet needs to be fitted, here are the before and after shots:
Before
After
Sorry for the quality...they are just quick snaps.
But anyway, my speakers are 23cm x 22cm x 40cm WxDxH.
I am looking to have that wall where my computer stuff is to for my bed as it is straight, and use my uneven wall to have a desk and some speaker stands.
Here is where the problem starts. Do I go for a separate rack unit for my amplifier (with the foresight to add a DAC, CD Transport and a tuner at a later date) and put my speakers on stands, or could I get away with putting my amp and computer on a desk (I'm replacing that desk as it is falling apart) and then add some speaker stands? Just that racks are expensive, and it's proving difficult finding one to accomodate my large amplifier that is cheap enough.
I was looking at various Apollo and Atacama stands which all seem to have plate sizes of about 18cm by 18cm or something...is that really going to be enough for my Heybrooks?
I'll be looking to buy some of those spike shoes, as the stands will be on carpet. What will be the best way for my speakers to stand on the speaker stands? Will blu tac suffice, or are those neoprene pads more advisable?
I cannot think of anything else which I should raise, all help greatly appreciated!
Before
After
