Help with Hybrid Sleep
31 May 2005
Alfreton,Derbyshire
I used to use Hibernation a lot but thought I would give Hybrid sleep a go to see how it went. If i don't switch the machine off at the wall all is well the same as if I was just sleeping the machine, it instantly resumes and all is ok. If I turn the machine off at the wall overnight say whilst in hybrid sleep the machine turns on when next required and then after a second or so switches off again. Then if I power it up again once more it resumes fine. Little odd just wondered if anyone has any ideas?
