Help with ideas for a Lid for this?
30 Jul 2005
Midlands
gone through 4 versions now making this case and iv got the bottom part sorted just need ideas on how to attach a lid to it. dont want to glue one on so need ideas on ways to making a lid that stays firm but can be taken off it need be.
pics:
V1
V2
V3
V4
V4 has a lot more internal bracing and strength to it now. made this using tinkercad.
I would make the walls at least 2mm thick and then do a 1mm offset on the top wall plane and extrude this by 2mm, then do a combine and cut with the top case. This will make the top and bottom interlock. You can then use cantilever snap fit tabs for extra hold.
