Help with images not loading
15 Jan 2011
Midlands!
Hey there, some of the images on a website I have done for my dad are not loading and yet some are....
Would you be able to take a look and see what might be the problem?
www.realbeeragency.com
edit: other links
http://www.realbeeragency.com/products.html
http://www.realbeeragency.com/contactus.html
for the other pages I have messed up the links so you will have to change the link in the address bar from: Products to all lower case. Same with any others in the address bar.
Ill be sorting this once I get home, but would like to know why the images aren't loading =/.
Love it how I posted a thread and then solved it myself....
thanks for clarifying my issues though Tripnologst!
Will fix it later, which unfortunately involves re-inserting all of my images. *sigh*
Shouldn't take long to re-upload to the correct directory. If they need to be in different directories then use find and replace in your text editor to sort out the references to the images.
