Help with improving memory speed (AMD)
28 Apr 2011
North West
Hello, I'd like some help improving my memory speed if possible.
I ran my amd overdrive benchmark and my memory speed is really low compared to other results
Integer Compulation - 18880
Floating point compulation - 18860
Memory speed - 3272
Cache speed - 17131
Sys performance - 5814
My cpu is AMD phenom x4 955 be OC'd to 3.6ghz
My memory is ddr3 Corsiar x2 2gb 1600hmz and patriot ddr3 x2 2gb 2250mhz
mobo is gigabyte GA-890FXA-UD5
I went into the bios M.I.T section and put the 'memory clock' setting from 4 to 8(max) and says 1600mhz.
Is this all I can do, or is it even increasing the ram clock speeds? in my mobo manual it says *Support for DDR3 2000(OC)/1333/1066 MHz memory modules*
As you can probably see I'm a newbie when it comes to this stuff, just wondering.
Corsiar in slots 1+2
http://i210.photobucket.com/albums/bb110/ReisD/corsiar.png
Patriot in slots 3+4
http://i210.photobucket.com/albums/bb110/ReisD/patriot.png
Thank you very much for any help.
