Hi,
I'm hoping someone can help.
I am still running AGP graphics and have a 9800 Pro which has been running fine for ages. I recently bought a second hand Asus AX800XT Platinum Edition as a last upgrade on AGP.
I uninstalled the drivers on the old 9800 Pro and then installed the new card as normal. The problem I am having is with installing the drivers.
I tried the latest ATI drivers and once they are installed the system asks to be rebooted. On reboot all I get is a continuous loop. Windows never actually boots and it just goes round in circles and back to the bios memory check etc screen.
I tried different drivers and even the latest from Asus. Some drivers install ok but sometimes I will get a black screen with a cursor in the top left of the screen. The only way out is for me to press the reset button.
Once the drivers are installed and the PC is restarted I then get a message saying the device cannot start because no ATI driver is installed. I checked the device manager and I am getting different error codes. These codes are 1, 10 and 28.
All refer to the driver not being installed. I uninstalled the drivers and then tried a manual install from add new hardware in the control panel. I managed to get the card working and everything is fine in the device manager until I reboot my PC.
On reboot the problems start all over again from the continuous loop to the black screen and the error codes.
So far I have tried the lastest and older ATI/Asus drivers but all give the same problems.
I have reset the bios config incase of a conflict. I have even re-installed Windows.
I am using the PC fine at the moment but as soon as I restart I will have to manually install the drivers again. Basically I have to install the drivers each time I want to use my PC.
Any ideas?
Thanks
Dan
Any ideas?
Thanks
Dan
